1998 Ford F-150 front brakes
GSRULS299
  • 1998 FORD F-150
  • V8
  • 138,000 MILES
The pad keep smokng on a 1989 ford f 150 1/2 ton we put new
calipers on it & thay still lock up & brun brake pads up but when it rains thay work fine we have not replace the brak lines or master cinder or the boster it`s the right side thats doing that the calipers been replace 3 times now
Do you
have the same problem?
Tuesday, May 19th, 2009 AT 8:03 PM
RACEFAN966
  • EXPERT
Ok if it is only one side I would checking that brake line out really close and see if it looks pluged from the inside. I have seen the inside liner brake and make like a one way valve you step on the brake and the line keeps fluid pressure to that caliper. I would also make sure that all the hardware is new too. If you need more help just get intouch via private message as I do not recheck the free listing. Thanks.
Tuesday, May 19th, 2009 AT 10:06 PM
Recommended Guides
