1998 Ford F-150 check engine light
STONEY014
  • 1998 FORD F-150
  • 6 CYL
  • 121,000 MILES
Question my check engine light comes on then a maybe a day later it goes off had all my sessors replaced check engine came back on again the code was bank1 sessor2 what should I do? Or what should I look for?
Do you
have the same problem?
Monday, August 24th, 2009 AT 12:09 PM
  • EXPERT
Hi there,
check for any exhaust leak up stream of the O2 sensor, check for any vacuum leaks check the continuity of the o2 wiring from the sensor to the ECU, start here.
Mark (mhpautos)
Monday, August 24th, 2009 AT 5:46 PM
MJR346
Bank 1 sensor 2 is the right rear o2 sensor behind the cat on passenger side. Without code, hard to diagnose, but either sensor is not outputting, wires are open, burned on exhaust, or cat has internal issue with it (usually bad o2s and internal issues lead to a p0420)
Monday, August 24th, 2009 AT 9:04 PM
