1997 Ford F-150 lower ball joint boot
SPIDEYOU2
  • 1997 FORD F-150
Suspension problem
1997 Ford F150 V8 Four Wheel Drive Automatic
can you tell me if its possible to put another rubber boot on my lower ball joint without taking everything apart. Can I loosen the nut and split the boot and slide it on. And maybe seal it up. And if so what should I use to seal the seam of the boot. Thanks
Do you
have the same problem?
Tuesday, July 21st, 2009 AT 6:03 PM
WAY2OLD
  • EXPERT
You will be wasting your time trying to do that. I don't think there is any adhesive that will hold the rubber together. Best bet is to disassemble and install full boot.
Tuesday, July 21st, 2009 AT 6:49 PM
