1997 Ford F-150 Dome/interior light
MLGORC
  • 1997 FORD F-150
Electrical problem
1997 Ford F150 V8 Four Wheel Drive Automatic
After opening the door the dome light will flash a few times then go out until you start the truck, after starting the truck it comes on normally after closing the door it flashes somemore then goes out. What could be causing the light to flash?
Do you
have the same problem?
Sunday, June 22nd, 2008 AT 9:29 PM
LEGITIMATE007
  • EXPERT
You may have a faulty switch in the door jamb
Sunday, June 22nd, 2008 AT 9:37 PM
Recommended Guides
