1997 Ford F-150 fuel filler neck
TCOX1160
  • 1997 FORD F-150
1997 Ford F-150 V8 Four Wheel Drive Automatic
im replacing the fuel filler neck on a 1997 ford f-150 and am looking for a web site that I can purchase the part for cheap any ideas? Also any advice as to how to tackle the job would be greatly apprecited.
Do you
have the same problem?
Wednesday, September 22nd, 2010 AT 9:20 AM
  • EXPERT
It is a straight forward job. You shouldn't have any trouble. Open the lid where you fill the tank from and remove the screws that hold the filler tube to the body. From there, it is attached to a rubber hose. It should just be clamped on.
As far as getting a new one, that is a dealer item only. If you are looking to save money, you may want to try a salvage yard.
Wednesday, September 22nd, 2010 AT 1:18 PM
Recommended Guides
