1996 Ford F-150 runs bad when the engine heats up
MARKO081068
  • 1996 FORD F-150
Engine Performance problem
1996 Ford F150 6 cyl Two Wheel Drive 180 miles
my truck wants it runs for about 15 min will just running bad and you can start smelling gas
Do you
have the same problem?
Wednesday, August 4th, 2010 AT 12:39 AM
  • EXPERT
Have you checked fuel pump pressure? You may have a bad regulator. Also, has the check engine light come on?
Wednesday, August 4th, 2010 AT 1:53 PM
  • EXPERT
Have you checked the regulator? Also, let me know if the check engine light came on.
Sunday, August 22nd, 2010 AT 9:40 PM
MARKO081068
No I sure havent noticed a check engine light
Monday, August 23rd, 2010 AT 2:22 AM
  • EXPERT
You need to check the fuel pump pressure and the regulator. If you need directions, let me know. Also, let me know what you find.
Monday, August 23rd, 2010 AT 10:14 PM
Recommended Guides
