1996 Ford F-150 DUEL FUEL TANKS
ANNALISHA
  • 1996 FORD F-150
  • 6 CYL
  • 87,000 MILES
I DISCONNECTED MY FRONT FUEL TANK AND NOW THE TRUCK SEEMS TO KNOCK IF SITTING FOR SHORT PEROID OF TIME WARMED UP IF I TURN IT OFF IT WILL NOT START UNTIL COOLED DOWN. DOES IT HAVE TO DO WITH THE ONE TANK BEING DISCONNECTED?
Do you
have the same problem?
Friday, June 5th, 2009 AT 7:17 AM
BMRFIXIT
  • EXPERT
What you mean by disconnected
did you disconnect the fuel lines
did you disconnect the wiring
did you remove the tank
was any rewiring done
was any fuel rerouted
if so recheck the work you done
if not do a fuel pressure test
good luck
let me know
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Saturday, June 6th, 2009 AT 6:06 AM
Recommended Guides
