1995 Ford F-150 starts hard, then dies
DDHELMERS
  • 1995 FORD F-150
The radiator hose ruptured and spewed fluid all over the engine compartment. After parking the car, replacing the hose, and adding coolant, the car wouldn't start. Only after checking all electrical contacts, testing the starter and battery did we have luck getting it to turn over. After about 15 minutes of cranking. However, if you let off the gas it dies in about 30 seconds. Been able to get it to turnover 3 times, but no luck keeping it going. Thoughts on next steps?
Do you
have the same problem?
Friday, December 8th, 2006 AT 10:50 PM
HEY_WIRE
There is a posibility that when ever your hose busted it spewed fluid into your breather and then into your carb supposing you have a carb and then from there it got mixed with your gas if you got alot in there then that could explain that if you think that is a posibility I would suggest draining out as much as posibly
best of luck
Friday, December 8th, 2006 AT 11:34 PM
BLANCHETTE
TRY REPLACEING THE CAP AND ROTOR
Sunday, December 10th, 2006 AT 1:05 PM
Recommended Guides
