Replacement of Gas Tank?
RYAN_DYL
Not yet. Does ford have a specific number or is it just their main number?
Tuesday, July 7th, 2020 AT 3:15 PM (Merged)
  • EXPERT
I would just contact a dealer.
PAT JACKSON
  • 1991 FORD F-150
Engine Performance problem
1991 Ford F150 V8 Four Wheel Drive Automatic
when I switch to front gas tank engine dies rear tanks works fine plus is there a way to drain front tank without removing tank thanks
BLACKOP555
  • EXPERT
Only other thing you can do is switch to front tank. Take off fuel hose and wire the pump to turn on the eec iv relay so the pump runs with key on. Be careful not to overheat and ruin the pump.
Problem with rear tank is probably a bad fuel pump. Put a funnel in gas tank and turn key on and listen if you dont hear pump buzzin it may be bad. So go under and kick the tank or hit it hard with a soft face mallet while having someone turn key on and off. Do you hear it engage now? If so chances are the pump is starting to go
