1995 Ford F-150 shift selector will not Move
GEORGE MATERN
  • 1995 FORD F-150
  • V8
  • 4WD
  • 150,000 MILES
Shift selector will not move unless I disconnect the battery, then it moves fine. It also blows the brake light fuse. Ive also found the third brake light is totally fried. This will need further investigation.
Do you
have the same problem?
Tuesday, September 28th, 2010 AT 9:10 PM
BLUELIGHTNIN6
  • EXPERT
Most likely culprit is faulty brake light switch
Tuesday, September 28th, 2010 AT 9:19 PM
Recommended Guides
