1995 Ford F-150
410A
  • 1995 FORD F-150
  • V8
  • 185,671 MILES
MY F150 shakes bad at high idle, RPM 800 and vacuum 20''
Do you
have the same problem?
Monday, November 8th, 2010 AT 10:47 PM
  • EXPERT
When was the last tune up? Does the shaking or missing go away when it isn't at high idle?
Tuesday, November 9th, 2010 AT 7:16 AM
410A
Last year and shakes all the time
Tuesday, November 9th, 2010 AT 10:32 PM
  • EXPERT
It doesn't sound like a vacuum leak. That sounds good. As far as the tune up, it should still be fine. However, a wire or plug may have gone bad. You checked fuel pressure and it is good. Have you checked timing? Have you checked engine compression? Has the check engine light come on?
Wednesday, November 10th, 2010 AT 1:26 PM
Recommended Guides
