Timing chain and tensioner replacement?
HJA
  • 1999 FORD F-150
  • V8
I have a rattle in the engine compartment when I first crank it up, or when there's a need to accellerate hard. I was told I may not have to change my timimg chain it may just be the tensioner. Where can I find video's or photo's of the timing chain/tensioner being removed/installed on the 1999 5.4ltr F-150. I've located the instructions, but remain skeptical about using them, because it doesn't mention anything about the camshaft alignment or turning the engine to TDC before removal.
Sunday, July 17th, 2011 AT 10:34 PM
  • 31,938 POSTS
There are 3 special tools required to do the chain replacement, see pic for part No and warnings. The guides below show how to replace the timing chain tensioner and timing cover. Check out the diagrams (Below). Please let us know what happens.
Monday, July 18th, 2011 AT 11:50 AM
HJA
Thanks I need to find these tools as soon as possible, does the local parts storesell these tools.
Tuesday, July 19th, 2011 AT 5:24 AM
  • 31,938 POSTS
Normally dealer only, but you can try specialist auto tools.
Tuesday, July 19th, 2011 AT 7:21 AM
CHYY08
  • 1999 FORD F-150
  • V8
  • 295,000 MILES
This truck has overhead cams and can they be adjusted or is there an automatic tenchner?
Saturday, August 22nd, 2020 AT 11:19 AM (Merged)
  • 31,938 POSTS
Hi there,
There is no provision to manually adjust the chain tension, there is a timing chain tensioner fitted to the system.
Mark (mhpautos)
LONEWOLF_65
  • 1994 FORD F-150
  • V8
  • 4WD
  • 160,000 MILES
I have every thing torn down to the timing chain cover but I can not seem to get the harmonic balancer off, got a puller but am I suppose to take the bolt off the crankshaft to get the balancer off?
Saturday, August 22nd, 2020 AT 11:20 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
You have to remove center bolt and use the puller to remove the harmonic
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
DUSTIN20
  • 1994 FORD F-150
  • V8
  • 120,000 MILES
We need to find out the locations of the bolts for the cover because the vehicle broke down and we have no way of figuring out where to place them so please. Help?
  • 108,170 POSTS
Are you sure the timing chain is the problem? Also, which V8 do you have? Also, once you remove the fan, and the waterpump, you will see the timing chain cover. THe bolts will go around the the cover.
Let me know what happened. Maybe it is something other than the chain.
PAUL MOSER
  • 1994 FORD F-150
  • 5.8L
  • V8
  • 4WD
  • 155,000 MILES
Taking off the water pump, the lower bolt on the left (passenger) side broke about half an inch deep in the timing chain cover. I am trying to get the timing chain cover off so I can devise a way to get the remainder of the bolt out. All bolts out of the timing chain cover but will not budge to that side, is the broken bolt threaded into the cover and holding it on or are the threads just in the block? Do you have any suggestions for removing the bolt without taking the timing chain cover off? Any help would be appreciated.
  • 52,797 POSTS
Good morning.
Assuming you removed the oil pan bolts at the front of the pan and it will not move, then it sounds like the bolt broke because it is frozen in the housing not letting it release.
I would get some Freeze Off and spray it in there and see if it will help devolve the rust and let the housing release.
BIG T
  • 1993 FORD F-150
  • 250,000 MILES
It back fire I can be driving and it shuts off acts like it wants too start but want has a new fuil pump new dist new wires new plugs and it would knck real hard but when it start it smooth out know knocking but want start at all now help!
Saturday, August 22nd, 2020 AT 11:21 AM (Merged)
  • 108,170 POSTS
You need to removing the timing chain cover to check if the chain has jumped or you can check if the #1 cylinder is at top dead center when the timing marks are on TDC at the harmonic balancer. If it doesn't start at all now, check to make sure it is getting spark and fuel to the engine. See if it will start with starting fluid. If it does, it is fuel related. If it fails to start with starting fluid, it usually is ignition related unless there is low compression or it is out of time.
Saturday, August 22nd, 2020 AT 11:22 AM (Merged)
