No start
WKFORBES
  • 1994 FORD F-150
  • 6 CYL
  • 131,000 MILES
Truck will crank but no start. The cranking seems fast enough, fuel pump does operate when key turned on. When key moved to start postion engine warn, yellow, light stays on no start. If light goes out engine starts.
Have checked connectors and replaced relays in remote electric box. This has been going on for about 12 months, but if temp is low and not damp no problem. Damp or rain seems to make it worse. Any help would be appreciated.
Do you
have the same problem?
Wednesday, April 1st, 2009 AT 6:32 AM
BMRFIXIT
  • EXPERT
Check wiring harness and relay connector
Wednesday, April 1st, 2009 AT 6:34 AM
Recommended Guides
