1994 Ford F-150 mechanical advice
LBUSCH
  • 1994 FORD F-150
  • 6 CYL
  • 205,000 MILES
Truck runs great when I first start it after aprox. 25-or so hwy miles at 65mph starts to cut out and eventually dies. I ll pull over turn key off wait about 5-10mins runs great again and repeats cycle. All gauges are normal. Recently changed fuel filteralong with new wires, plugs, rotar and cap. Any suggestions. Thank-you
Do you
have the same problem?
Tuesday, March 2nd, 2010 AT 8:05 PM
LOGGER9409
Try having the ignition module checked at a autozone or a suitable auto supply store. Sometimes when the module is going bad it gets hot in about that ammount of time, and when it quits it takes 5-10 min to cool off hence starting again hey give it a try. It is either on the distributor or on the firewall drivers side you will need a special screwdriver to remove it.
Monday, March 8th, 2010 AT 8:55 AM
Recommended Guides
