1994 Ford F-150
CRASH729
  • 1994 FORD F-150
1994 Ford F150 V8 Four Wheel Drive Automatic
I have a 94 F150 and when I switch to one tank it won't start like it doesnt have any gas in it but when I switch to the other tank it starts right up. And when I switch to the other tank it will just die. Any help would be great. Thanks
Do you
have the same problem?
Monday, January 19th, 2009 AT 5:48 PM
DAVE H
  • EXPERT
Fuel delivery systems differ in design depending on model. System designs use one of the following configurations:
Single tank with single pump.
Single tank with dual pump.
Dual tank with mechanical selector valve/reservoir.
Low Pressure Fuel Pump
Some vehicles have a primary, low pressure in-tank pump for supplying fuel to reservoir. The low pressure pump rests in a sump (depression) in fuel tank. A nylon screen protects low pressure pump inlet from contaminating particles.
When dual tanks are used, each tank is equipped with a low pressure pump. Such a system has a total of 3 pumps: 2 low pressure and one high pressure.
High Pressure Fuel Pump
The high pressure fuel pump is positioned inside fuel tank. A reservoir is built onto pump and sender assembly.
In a 2-tank system, sender assembly handles switching of high pressure fuel through internal valves. Should one tank overfill during use (return line returns fuel to wrong tank), pump and sender unit in overfilling tank need replacement.
The high pressure fuel pump is capable of pumping over 33 gallons (125L) of fuel per hour at a working pressure of 39.2 psi (2.75 kg/cm2 ). This pump also has internal pressure relief and discharge check valves.
Mechanical Selector Valve
A driver-operated selector switch controls selector valve for switching fuel supply from one tank to another. This valve switches fuel supply and return lines from one tank to another in response to fuel pressure from in-tank pumps acting on its actuating diaphragm.
The diaphragm switches tank connection when less than 2 psi of fuel pressure is acting on upper side of front tank and lower side of rear tank. Valve function depends upon proper operation of in-tank low pressure pumps. In all dual-tank vehicles, excess fuel not used by engine is returned to same tank from which it was pumped.
Monday, January 19th, 2009 AT 6:35 PM
Recommended Guides
