1993 Ford F-150 Headlights
PBRMAY
  • 1993 FORD F-150
  • V8
  • 4WD
  • 165,000 MILES
My parking lights and my tail lights will not shut off. I have pulled all the fuses and they still will not turn off.
Do you
have the same problem?
Monday, January 11th, 2010 AT 8:09 PM
  • EXPERT
If you pulled all fuses, they should have gone off. The fuse is a break point to power to the lights. If they stay on, even with all fuses pulled, there has to be a constant power source not affected by a fuse. Do the headlights turn off? If they do, the only thing I can think of would be the actual headlight switch. You should check that and see what you find.
LEt me know.
Monday, January 11th, 2010 AT 10:28 PM
Recommended Guides
