1993 Ford F-150 Ford 83 F-150 inline 6 300
BLAHHH
  • 1993 FORD F-150
Engine Mechanical problem
1993 Ford F150 6 cyl Four Wheel Drive Manual
I was driving down the road and my truck just started bogging out and then went normal again. So I stoped and everything looked normal so I drove on. It kept doing it over and over again in random times but I had to make it home. Then it bogged all the way down and hasn't started since. And while I was trying to start it I turned my key to the start position and nothing happened. The battery isn't dead. Please help
Do you
have the same problem?
Saturday, September 11th, 2010 AT 7:07 AM
  • EXPERT
Have you checked all battery terminals? Are they tight and clean including the ground on the engine block? If they are good, have you checked the ground from the battery to the engine block?
As far as the description you gave, it sounded like a fuel pump problem, but we need to get power back before checking that.
Let me know what you find.
Saturday, September 11th, 2010 AT 8:39 PM
Recommended Guides
