1993 Ford F-150 dead cylinder #6
DAN.DNA
  • 1993 FORD F-150
  • 6 CYL
  • MANUAL
  • 85,000 MILES
I did a compression test on cylinder# 6 and compresion was below 10. I have the inline 6 motor.
Is there a way to find out if its just the valve problem and not the actual piston in the cylinder without pulling the motor apart?
Do you
have the same problem?
Tuesday, May 19th, 2009 AT 11:15 PM
Do a cylinder leakdown test
Wednesday, May 20th, 2009 AT 1:03 AM
Recommended Guides
