1992 Ford F-150 vibrating on acceleration
FORDGUY2323
  • 1992 FORD F-150
  • 6 CYL
  • 180,000 MILES
When I accelerate, there is a vibrating or grinding noise that comes from the engine or transmission. It only happens past third gear and after it happens it shifts hard.
Do you
have the same problem?
Tuesday, September 1st, 2009 AT 7:16 PM
IMPALASS
  • EXPERT
Hello -
I looked over all the TSBs and didn't see anything related to this. With the miles you have on it my suggestion is to go to a place like AAMCO or another transmission shop that tests your vehicle for free. They can check it out and let you know and provide an estimate.
You might check your drive shaft, u-joints for wear and lack of lubrication also.
Wednesday, September 2nd, 2009 AT 10:17 PM
Recommended Guides
