1991 Ford F-150 Performance
TAZZMANX2
  • 1991 FORD F-150
  • V8
  • 71,000 MILES
I am having problems with my ford. It will start up great in the morning smells a little rich, after it is warm up, it is a lot harder to start. And it will hesitate when I give it some gas. When I shift up into overdrive it jerks. Has new plugs, wires, cap, air filter. Can you give some idea where to start.
thanks
Do you
have the same problem?
Thursday, May 14th, 2009 AT 11:25 PM
RACEFAN966
  • EXPERT
Ok I would check the tps (throttle position sensor). Get a digital multi meter and a paper clip. Back probe the green wire to the tps and then with key on engine off hook up your meter and you should have.8 to 1 volt now slowly lift the throttle and it should slowly and steadly increase to 4.5 to 5 volts. If there is any glitches or drops in voltage as you do this replace the TPS.
Wednesday, May 20th, 2009 AT 8:56 AM
Recommended Guides
