1990 Ford F-150 won't fire
SAM STAYROOK JR
  • 1990 FORD F-150
  • V8
  • 4WD
  • 100,000 MILES
When cold my truck starts good but when it gets warmed up it dies and don't have no fire then. Then just cranks and don't fires
Do you
have the same problem?
Sunday, February 14th, 2010 AT 9:15 PM
When it gets warmed up it dies and don't have no fire then-if you meant no spark-check and test below
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor camshaft and crankshaft sensors and computer. Note: If it doesn't apply disregard it
Sunday, February 14th, 2010 AT 10:16 PM
Recommended Guides
