1990 Ford F-150 wiring
FORD MAN CHRIS
  • 1990 FORD F-150
Electrical problem
1990 Ford F150 6 cyl Two Wheel Drive Manual
My fuel pump runs, my ignition is sparking, but it seems as though the injectors aren't working once I crank the engine. I can hear them click, when I first turn my toggle switch on, and when I first crank it it hits like it wants to start, but won't unless I turn the switch off and back on, and it just hits again but won't start. New fuel filter, distributor, coil, stator, plug wires, and fuel pump, also O2 sensor. Ignition system completely redone, and mostly all new fuel system, except injectors, and computer.
Do you
have the same problem?
Monday, March 15th, 2010 AT 9:29 PM
Verify your fuel pressure with a gauge if its within specs and get back with the readings we start here.
Monday, March 15th, 2010 AT 9:44 PM
FORD MAN CHRIS
My fuel common rail psi is 45-50
Monday, March 15th, 2010 AT 10:07 PM
What liter engine? 4.9 5.0 5.8?
Is this KOEO or KOER readings?
Tuesday, March 16th, 2010 AT 1:50 AM
FORD MAN CHRIS
My engine is a 4.9L inline 6 also known as a 300-6
Tuesday, March 16th, 2010 AT 1:05 PM
Key On Engine Off 50 - 60 psi
Key On Engine Running 45 - 60 psi
Tuesday, March 16th, 2010 AT 1:47 PM
FORD MAN CHRIS
Fuel pressure has been verified, except for with the engine running because the engine won't start. I'm trying to find out what else could possibly make the engine not run. It seems as though the injectors aren't getting a pulse signal, and I need to know what to check for that.
Tuesday, March 16th, 2010 AT 4:17 PM
Hook up a noid lite at the injector/s harness connector it should be flashing if the circuit is good if it does-its coming from the injector/s
Tuesday, March 16th, 2010 AT 5:34 PM
FORD MAN CHRIS
I'll try it, and let you know. Thanks
Tuesday, March 16th, 2010 AT 8:09 PM
FORD MAN CHRIS
I put a noid light on the injector plug in, and both sides of the plug make the light come on but not flash, this was done with the engine being cranked, but not running.(Since it won't start).
Friday, March 19th, 2010 AT 9:32 PM
The injectors ground drivers of the computer went south-it should be flashing if the ground drivers are good
Friday, March 19th, 2010 AT 11:39 PM
FORD MAN CHRIS
So does that mean I need a new computer, or could it be a short somewhere in the wiring?
Friday, March 19th, 2010 AT 11:40 PM
If you test the wiring and they all good replace the computer
Saturday, March 20th, 2010 AT 12:04 AM
FORD MAN CHRIS
Okay, I'll try that. Thank you.
Saturday, March 20th, 2010 AT 10:32 PM
FORD MAN CHRIS
Okay, I got the other problem fixed. Finally!
I got a new problem though, there is a really foul smell in my vent system, and around the truck, kinda smells like dead rat, it's really bad when I turn the dash blower on. No vibration in the fan, just a foul smell !
I would like to know what I need to do to get the culprit out before it gets really nasty. This smell is really bad. Please, help.
Wednesday, March 24th, 2010 AT 12:25 AM
Recommended Guides
