1990 Ford F-150 No electrical power
P5AUDET
  • 1990 FORD F-150
Electrical problem
1990 Ford F-150 V8 Four Wheel Drive Manual
I discharged my battery while hunting and had to get a jump. Drove home, approx 3.5 hours, shut it off and it started again approx 1 hour later. Drove another 1.5 hours and parked it for two days. Went to start it and there was zero power. Replaced battery, and there was still zero power. What could have gone wrong after letting it sit for two days other then the battery discharging again? Replaced starter switch and tried to jump it. Didnt work. There was still no electric to anything. No door chime, no radio, no windows. Its like there is no battery attached, with or without a jump. Checked the old battery and it has a full charge so will be returning the new battery. Guess the alt is fine. Thanks for any assistance and for your time.
Do you
have the same problem?
Monday, November 8th, 2010 AT 4:04 PM
Inspect and test all the fusible links-
Monday, November 8th, 2010 AT 4:12 PM
Recommended Guides
