1989 Ford F-150 no tension when I turn the key to run
SPYDERSLAYER1
  • 1989 FORD F-150
  • V8
  • 4WD
  • MANUAL
  • 150,000 MILES
I, ve tried replaceing the ignition switch n it didnt do it I also tryed replacing the electrica switch thats mounted on top of the sterring colum what else can it be and how do I fix it?
Do you
have the same problem?
Friday, January 4th, 2008 AT 3:50 AM
BLACKOP555
  • EXPERT
Did you change the ignition tumbler?
Friday, January 4th, 2008 AT 9:02 AM
Recommended Guides
