My check engine light is on?
NOLANPW
  • 1991 FORD F-150
Electrical problem
1991 Ford F150 6 cyl Two Wheel Drive Manual 134K miles
Having problems with the engine cutting out
and hard to restart and occasional Check Engine
Light as well.
When turning over the engine, the check engine
is on and the engine is running ruff, smoke and
fuel coming out the tail pipe, until all cyclinders
catch and fire. Then it runs great with no problems.
Usually happen when it sits for a while.
Put in new plugs/wires and cap and it ran good for a while, now it is happening again.
Working my way back from the plug, the next step is to replace the rotor. Does this require the timing to be reset?
Any suggestion in solving this would be appreciated.
Regards.
Wednesday, May 14th, 2008 AT 11:54 AM
OBXAUTOMEDIC
  • 3,711 POSTS
OK, First off I suggest anytime you change the Cap you change to Rotor. Only makes sense. Why would you want to remove the Cap twice? Oh, and no it doesn't require the timing to be reset.
A couple questions....
Have you had the codes pulled? If not do so and post here using this guide
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
What did the Plugs look like when you removed them? Any one look different than the others... example covered with oil soaked with gas , deposits....
How long did it run good for once you replaced the Plugs cap and wires? How many Days , weeks, etc.
Post response here.....
Wednesday, May 14th, 2008 AT 1:58 PM
NOLANPW
OK, First off I sugguest anytime you change the Cap you change to Rotor. Only makes sense. Why would you want to remove the Cap twice? Oh, and no it doesn't require the timing to be reset.
A couple questions.
Have you had the codes pulled? If not do so and post here.
What did the Plugs look like when you removed them? Any one look different than the others. Example covered with oil soaked with gas, deposits.
How long did it run good for once you replaced the Plugs cap and wires? How many Days, weeks, etc.
Post response here.[/Quote:22781a3869]
Thanks for the information.
After the plugs/wires and cap were replaced,
it ran for a couple of days before it cut-out and hard
to start and ran rough until again fired properly.
It seemed it was hard to start because it was flooded.
The Dealer was unable to get any code; did not find
any problems and even drove it for a while.
As for the pugs, they did look moist across the set. Also, changed the oil and noticed what look like gas infiltrated the oil.
Thursday, May 15th, 2008 AT 2:25 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, if you have a fuel pressure tester test the fuel pessure and pressure regulator. You may also want to check the Injectors they are probably dirty and not giving correct spray pattern or they are leaky and need to be replaced.
Your fuel system will not give off any codes. So anytime you have a problem and no codes are given then the problem could be fuel related.
Thursday, May 15th, 2008 AT 9:42 PM
MOCHOA
  • 1991 FORD F-150
  • V8
  • 4WD
  • MANUAL
  • 105,000 MILES
My check engine light comes on about five minutes after I start my truck. I have ran a code scan on my truck with a Actron code scanner and have gotten with the KOEO codes of 83 and 84 and the code have to do with EGR control solenoid and EGR Shut off solenoid circuit failure. I have replaced the EGR solenoid. My engine light still comes on and get the same scan codes after I have replaced the EGR solenoid. Can you please help?
Thursday, September 10th, 2020 AT 10:40 AM (Merged)
RACEFAN966
  • 5,029 POSTS
Ok which solenoid did you replace? Where was it located? Was it on the egr valve the position sensor or was it on the intake where the vacuum lines and electric plug to to? Let me know so I get you the test to the other componants ok. Thanks
MOCHOA
The solenoid was by the intake manifold and has two vacume lines attached to it and an electrical plug with two wires that plug into the solenoid component.
RACEFAN966
  • 5,029 POSTS
Ok first here is a chart with the pins and there numbers as you need a digital multi meter and the we will check to see why the egr system is having faults. Here is the chart. so you can print it.
https://www.2carpros.com/forum/automotive_pictures/249564_evp_1.jpg
FIrst unplug the solenoid so you can test pin 57. Set your multi meter on 20 volt scale and put positive side on pin 57 and neg. to good ground and turn on key and read voltage. If less then 10 volts then you need to find the bad part in that wire section and fix it. If more then you need to test resistance of pin 33 and ground on the 200 ohm scale if more then 5 ohms then there is a break in that circuit. Let me know what this brings ok.
TTUITE
  • 1991 FORD F-150
  • 6 CYL
  • 47,000 MILES
When driving I get an intermittent check engine light. No difference in performance when light comes on. After a while the light goes out. I have had the truck checked for codes and there are none. I have a slight hesitation on start up for first 30 seconds when temps are cold. Engine has slight ping or rap at 1500 rpm when going up hill. Biggest problem is vehicle get terrible gas mileage. About 10-12 MPG on combined city/highway. Changed wires, plugs and filters. Truck sat idle for about 9 months last year before I bought it. Very low miles and was used very infrequently by an older couple.
  • 108,128 POSTS
It could be a few things. However, without codes, everything becomes a guessing game. The ping on accelleration can be the result of a bad knock sensor. The poor fuel economy could be a bad O2 sensor.
Have you checked fuel pump pressure?
2CP-ARCHIVES
  • 4,542 POSTS
  • 1991 FORD F-150
  • V8
  • 4WD
  • 75,000 MILES
1991 Ford F-150 4x4 mileage: 75,000. I have been trying to solve some error codes for a while. I was getting all kinds of codes at first. I realized that my vacuum reservoir was rusted out. I have replaced it. I cleared codes and drove it for a period of time. I now get oxygen sensor errors 171 and 172 and 173. I seem to have terrible mileage also. After changing the vacuum reservoir, and still having O2 codes, I thought I needed a new O2 sensor. With the new sensor in place and running the vehicle on the highway for ten minutes, the service light comes on and stays on. I returned the sensor assuming I had a bad one. The new sensor seemed to help for a while but now the light comes on steady again after ten minutes on the highway, always with O2 sensor codes. I have also noticed that the vehicle starts much better in cold weather (-20) than it does in warm weather (around freezing temp). In warmer weather the engine seems to start and then miss immediately, giving similar characteristics of a flooded engine until it restarts. Any ideas would be appreciated.
2CP-ARCHIVES
  • 4,542 POSTS
Check the fuel pressure regulator, as it may need to be replaced. Also, check the fuel pump pressure because we have found that the fuel pumps in each of the tanks can work one day and not the next.
WIGHT5
  • 1990 FORD F-150
  • 6 CYL
  • 4WD
  • MANUAL
  • 125,000 MILES
I have a 1990 f150 with a 300 inline 6 i had it for about 2 weeks now and it doesnt seem to be getting as much power as i should. Im going up a hill and its maxing out at 45 mph. The check engine light came on so i took it to get tested and it said the computer isn't responding with the scanner. It also has one bad fuel pump. I was wondering if this is just how fast the truck will go or could it be the computer or maybe another bad fuel pump. Any ideas will be helpful.
Thanks bill
http://www.2carpros.com/forum/automotive_pictures/509408_AAA_1.jpg
JDL
  • 16,098 POSTS
Hi, thanks for the donation, nice looking truck. Whoever tried to check for codes, may be correct, but, I'd have to double check. You can check for possible codes, yourself. There should be two connectors, underhood driverside, fender. The info below shows two different ways, you can access codes, if possible. The top part, uses a jumper wire and analog multimeter, you count the needle swings in order to get the some codes. The bottom way, just uses a jumper wire, then the mil on the dash starts flashing, you count the flashes to get the codes.
How long since a tune-up. Check fuel pressure.
https://www.2carpros.com/forum/automotive_pictures/170934_ford_f150_1.jpg
Thursday, September 10th, 2020 AT 10:41 AM (Merged)
WIGHT5
I'm checking the fuel pressure tomorrow and the oil filter and gas filter are getting changed tonight. I took it to anouther place to get tested and they had the mb1 conection for testing the computer and still no read out.
2 LINSEY
  • 287 POSTS
Hi wight5, its been awhile since your last post were you able to get fuel pressure test results. If you have fixed your truck, well thats great and if not then let us know so we can finish getting your problem resolved. Thank you again.
JOSHUA_SCHELL
  • 1990 FORD F-150
Computer problem
1990 Ford F150 V8 Four Wheel Drive Automatic
I NEED HELP
it will run fine I get where im going and sometimes when I start it again it will turn over its hard to get started when it does start it burns rich and check engine light comes on shakes alot like its starved for fuel put my code reader on there and it say vehicle not responding and whats really weird is that the overdrive button wont work. Thanks josh
  • 108,128 POSTS
Is there black smoke from the exhaust?
JOSHUA_SCHELL
Yes there is black smoke from the exhaust
  • 108,128 POSTS
Two things that come to mind. First, the fuel pressure regulator or a leaking fuel injector, or a bad temp switch.
Start by checking fuel pressure. I will provide a how to for checking pressure and the regulator. Also, pay attention to fuel pressure drop off. That is when the key is turned off and the pump stops. If it drops off quickly, chances are you have one or more leaking injectors..
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
DELIVERMEFREE
  • 1989 FORD F-150
  • V8
  • 150,000 MILES
The engine light flashes sometimes, but ti stays steady @ 35 mph. There is no hesitation and seems to run smoothly. I have changed spark plugs and that seemed to make no difference with the light. What do I need to do? I can't get a diagnostic code if it want stay on continuously. I hope you can help.
