1989 Ford F-150 starting system woes
SIRK133
  • 1989 FORD F-150
Electrical problem
1989 Ford F-150 6 cyl Four Wheel Drive Manual
I'm fighting with my truck. I've replaced the starter, the starter solonoid, the starter cable. I can get the starter to spin if I jump the solonoid, but when I use the ignition, I get nothing, although I'm getting power to everything else hooked up, fuel pump runs, everything seems to cycle, just not getting any power to where it needs to go. I checked all the indash fuses, but none of them were blown. Any ideas?
Do you
have the same problem?
Saturday, November 6th, 2010 AT 1:56 PM
  • EXPERT
Are you getting power to the solenoid when you turn the key to the start position?
Saturday, November 6th, 2010 AT 10:13 PM
SIRK133
After posting my question, I continued to dig through the site and found another person with the same problem. It ended up being the clutch interlock switch thing on the firewall I put a bypass on it and no more problem, yay thanks for your help
Sunday, November 7th, 2010 AT 2:35 PM
  • EXPERT
Glad you got it fixed. Let us know if you have other questions in the future.
Monday, November 8th, 2010 AT 7:58 AM
Recommended Guides
