1987 Ford F-150 fuel drawing out of wrong tank
CRAIGH
  • 1987 FORD F-150
1987 Ford F150 6 cyl Four Wheel Drive
1987 f-150 dual fuel tanks fuel is drawing out of rear tank all the time even when switch is on front tank. Could it be the switch or something else that i'm over looking? Switch seems to work with test light & ohm meter as far as switching from one to the other go. Even tried a differant switch. I would be thankful for a point in a direction thanks
Do you
have the same problem?
Sunday, January 25th, 2009 AT 9:43 AM
BILLYMAC
  • EXPERT
Hi ford had a recall on the check valves on the fuel tanks. This is the prob you have. Check with ford give them your vin number. Ford was replaceing them for free. Thanks billymac
Tuesday, January 27th, 2009 AT 11:48 AM
