1985 Ford F-150 transmission problem
  • 1985 FORD F-150
Transmission problem
1985 Ford F150 6 cyl Two Wheel Drive Manual 177000 miles
hi my name is mark I have a 1985 ford f 150 pick-up truck its a 4x2 it has about 177000 miles on it and a three speed with overdrive manual transmission. I was driving to work today on the freeway when the truck would not get up to speed so I got off the freeway thinking that the truck needed to warm up a little bit more I let it warm up some more and proceeded on my way to work I had to drive up a hill and the truck felt like it didnt have the power to go up I made it to the top of the hill and when I tried to shift into another gear the truck would not shift into another gear I pulled the truck to the side of the road and it smelled like burning metal and I looked under the truck there was a bolt missing on the transmission. So my question is do you think the transmisson is shot or is it just the clutch that went
Do you
have the same problem?
Thursday, January 17th, 2008 AT 10:55 AM
  • 419 POSTS
What bolt was missing?
Thursday, January 17th, 2008 AT 8:03 PM
Recommended Guides
