1985 Ford F-150 speed control
EATALOT
  • 1985 FORD F-150
  • 6 CYL
  • MANUAL
  • 196,589 MILES
Sometimes it works &sometimes it dont speed control
Do you
have the same problem?
Monday, September 27th, 2010 AT 2:42 PM
BLUECOLLAR
I'll assume the truk has factory installed cruise? If so, try this: While driving 35 mph or over, turn the cruise on. Then push the set button. ALL WHILE MOVING THE STEERING WHEEL QUICKLY FROM 11 O'CLOCK TO 1 O'CLOCK. If it engages every time, you may need to replace the slip rings underneath the steering wheel. (Sometimes you get lucky and it'll work just by cleaning & applying new dielectric grease)
Monday, September 27th, 2010 AT 8:47 PM
Recommended Guides
