1984 Ford F-150 Oil leak location
ARCHPHILIP
  • 1984 FORD F-150
1984 Ford F150 V8 Two Wheel Drive Automatic
I have an oil leak on the top rear of my 302 engine. Could you tell me what could be leaking there? It seems to hit the dash firewall and run down. I thought at first it was the rear main seal, but I see now where it is running down from above.
Do you
have the same problem?
Wednesday, June 25th, 2008 AT 1:21 PM
BMRFIXIT
  • EXPERT
Check the valve covers and intake manifold gaskets
Wednesday, June 25th, 2008 AT 5:13 PM
Recommended Guides
