PCM location
GEOELBELL
  • 1994 FORD F-150
  • 6 CYL
  • 350,000 MILES
Can you please give me the PCM location?
Sunday, May 4th, 2008 AT 10:24 AM
The PCM is located under the power brake booster half in and half out of the firewall Here is the location diagrams below. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers.
Sunday, May 4th, 2008 AT 3:21 PM
VIRGINIAJONES
  • 1990 FORD F-150
  • 4.9L
  • 6 CYL
  • 50,000 MILES
Where is the pcm located?
Friday, November 23rd, 2018 AT 1:55 PM (Merged)
HMAC300
  • 48,601 POSTS
Behind left kick panel which is panel in front of door inside
VIRGINIAJONES
Thankyou so much! I found it, but now I need to know how to remove it please.
HMAC300
  • 48,601 POSTS
There is an electrical connection to unplug as well as few bolts probably. Why do you want to removei tin the first place. You'll have to scan for codes first to see if it is bad or a sensor. We don't show a pic of this so it's hard to describe not seeing something that old.
VIRGINIAJONES
Already had diagnostics run on it. They said it was the pcm. Thanks so much for your help
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,883 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Best, Ken
LOGGERHEAD
  • 1995 FORD F-150
  • 6 CYL
  • 4WD
  • 97,000 MILES
Where is the computer location it is not behind the passenger kick panel.
BMRFIXIT
  • 19,053 POSTS
No its on the left side firewall by the brake booster and wiring harness
HELPMATT
  • 1989 FORD F-150
  • 6 CYL
  • 160,000 MILES
Where is the pcm located on this vehicle?
BMRFIXIT
  • 19,053 POSTS
Try and check behind left kick panel
XPOOHX
  • 1983 FORD F-150
  • V8
  • 96,700 MILES
1983 ford f-150 302-2bbl does this vehicle have an engine control module(computer)? And where is it located? Ty
LH Inner Fender Well.
Above Ignition Module
Applicable to: 1981-83 w/MCU
TURTLE48
  • 1992 FORD F-150
Electrical problem
1992 Ford F150 V8 Four Wheel Drive Automatic
Where do I find the computer @ under my dash?
AIRSOFTSOLDRECN9
  • 348 POSTS
It is on the driver's side firewall comming from the engine compartment.
TOMMIZON
  • 1993 FORD F-150
Computer problem
1993 Ford F150 V8 Two Wheel Drive Automatic
where is the ECM
PCM see below
https://www.2carpros.com/forum/automotive_pictures/12900_ecm_6.jpg
TRACYF150
  • 1996 FORD F-150
  • V8
  • 157,000 MILES
I am trying to find out the location of the ECM/PCM on a 1996 Ford F150, can you help?
The Powertrain Control Module is located at the LH side of the safety wall.
F150LARIET
  • 1989 FORD F-150
  • V8
  • 4WD
  • MANUAL
  • 128,000 MILES
I own a 1989 F150 Lariet and have been experiencing problems with the electrical system. My truck runs fine one moment then completely goes haywire the next. To me it seems like I have an electrical short somewhere and have been feverishly been tracing wires looking for bad connections, pinched wires, or burned up wires. My eec relay "chatters", this relay controls my external fuel pump, and whenever the the problem occurs while driving I have to pull over as because the vehicle is completely undrivable. I replaced the relay and the problem continued. My next step I did was to run a bypass toggle to manually control the pump. But the problem continues. I have tried taking it to the shop but have been told that as long as it is not currently happening there is not much they could do. These problem happens at random intervals. My last episode lasted three months and I was unable to drive it at all so I parked my truck. When I ran the bypass the truck ran fine but alas the problem returns. The check engine light flickers and the truck dies. This problem burned up my last fuel pump from being turned on and off so much so fast along with the eec relay. I feel like the pcm is going bad or that something is sending the pcm bad signals which in turn cause the pcm to output weird signals. HELP ME PLEASE! What can I do?
