1982 Ford F-150 No Spark - Will not start
300F150
  • 1982 FORD F-150
  • 6 CYL
  • 4WD
  • MANUAL
  • 139,000 MILES
Can you give me some tips to fix my truck. It had been driving nicely, no problems stopped at a 7-Eleven and it wouldn't start back up.
I found that the started was bad; replaced.
Still will not start it seems that it doesn't have a spark.
Replaced Starter Solenoid - Not it!
Replaced Ignition Module - Not it!
Replaced Ignition Switch - Not it!
Replaced Coil - Not it!
The following compenents were replaced approximately 2 months ago when I got the truck back on the road after a long sit!
New distributor CAP & Rotor.
New Spark plug wires.
New Battery.
Also, I pulled the alternator out and had it tested - Functioning good.
Anyassistance you can give will be appricated!
Again this is a Ford F150 4X4 with the straight six 4.9L engine and a four speed manual transmission.
THANKS!
Do you
have the same problem?
Friday, May 9th, 2008 AT 11:52 AM
98RANGERXLT
Either your fuel pump or relay is bad
Friday, May 9th, 2008 AT 8:15 PM
Recommended Guides
