1982 Ford F-150 motor dies
CCRB1980
  • 1982 FORD F-150
Engine Performance problem
1982 Ford F150 6 cyl Two Wheel Drive Manual
i have checked ignition control module it tested good. But some days my truck runs great the next I get 4 blocks from home and the motor dies not stall just dies what is wrong?
Do you
have the same problem?
Friday, June 5th, 2009 AT 11:17 PM
BMRFIXIT
  • EXPERT
I would suspect a bad module and it failing when heating up very common
If the spark control module was replaced and wiring around it checked to be OK
suspect wiring and or relay check it at the left side fender area
good luck
let me know
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Saturday, June 6th, 2009 AT 5:56 AM
Recommended Guides
