Transmission won't engage in reverse
SIOMY
  • FORD EXPLORER
I have a 1998 ford explorer with 112000 miles 4.0 engine. I shifted into reverse it moved a few feet when I heard a thump and she stopped moving.
Now she won't even engage will I need to rebuild?
Do you
have the same problem?
Monday, October 8th, 2007 AT 4:28 PM
MERLIN2021
  • EXPERT
Maybe? The first gear you loose when the pump is weak is reverse! Takes twice the pressure drive gears do! Any leak between the engine and tranny?
Monday, October 8th, 2007 AT 4:38 PM
SIOMY
No leaks fluid level normal
she will engage on drive gear
Monday, October 8th, 2007 AT 6:42 PM
Recommended Guides
