Grease in the wheel well
BENLEGGETT
  • FORD EXPLORER
I have a 1999 Ford Explorer, 115,000 miles with a 4L V6 and 4 wheel drive. Recently had a new transmission put in and just replaced the wheel bearing on the front right passager side. Noticed today that there is grease in the wheel well and on the axle on the front right side. Thought we felt a slight grinding noise after replacing the wheel bearing. Not sure what this is from.
Do you
have the same problem?
Tuesday, July 3rd, 2007 AT 10:38 PM
MERLIN2021
  • EXPERT
Does your explorer have a CV-Joint? Check the boot!
Wednesday, July 4th, 2007 AT 8:24 AM
Recommended Guides
