Check engine light turns off and on
CH331206
  • FORD EXPLORER
I have a 1994 ford explorer xlt with 156000 miles on it, and a v6 engine. When ever I drive continuosly on the highway for more than a couple of hours the check engine lights turns on and turns off periodically, and when I come to a stop it idles rouph. What do you thinks going on?
Do you
have the same problem?
Sunday, September 30th, 2007 AT 4:14 PM
MERLIN2021
  • EXPERT
I think your car is trying to tell you! Have the code(s) read. Autozone will do it free. This will give you a starting point, Don't throw good money after bad!
Get it scanned for a possible OBD2 code/s the computer has identified a problem with the engine electronic controls could be a sensor/wire/actuator/computer itself. Then comeback with the code/s.
Sunday, September 30th, 2007 AT 6:17 PM
Recommended Guides
