HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Engine
Computer
Diagnostic Connector ALDL
Location
SPONSORED LINKS
OBD port location
STACEY_M68
MEMBER
2005 FORD EXPLORER
4.6L
V8
4WD
MANUAL
85,000 MILES
Need for a diagnostic check. Please help me. I love this site.
Saturday, August 2nd, 2014 AT 11:30 AM
HMAC300
MECHANIC
The ALDL connector is on the driver side facing downward. Here is a guide that will help you with the scan and the location of the connector below:
Cheers
Image (Click to make bigger)
SPONSORED LINKS
Saturday, August 2nd, 2014 AT 11:58 AM
STEVE51
MEMBER
1 POST
2005 FORD EXPLORER
Six cylinder four wheel drive automatic 42,000 miles.
Where is the computer diagnostic connector located? Does not seem to be under the steering wheel where I would expect to find it.
Tuesday, August 28th, 2018 AT 7:35 PM (Merged)
KEN L
MASTER CERTIFIED MECHANIC
The ALDL data link connector is at the bottom of the dash edge on the drivers side. Here is a guide to help you run the codes:
The location is (below).
Cheers, Ken
Images (Click to make bigger)
NEEDAMECHANIC
MEMBER
1 POST
2004 FORD EXPLORER
6 CYL
2WD
AUTOMATIC
103,876 MILES
Where is the data link connector?
MECHANIC
SPONSORED LINKS
Please
login
or
register
to post a reply.
Related Engine Computer Diagnostic Connector ALDL Location Content
Engine Safe Mode? Limp Mode?
I Disconnected The Battery For About Two Minutes And Now The Car Is In Safe Mode. Cannot Drive It Anywhere. What Can I Do? It Starts Up With...
Asked by
tulpa
3 IMAGES
2005
FORD EXPLORER
What Could It Be? The Main Computer Chip?
The Car Made A Pop Sound From The Engine And A Lot Of White Smoke Blew Out From The Exhaust Pipe, But The Car Just Went In For Service Two...
Asked by
Mahealanikuamoo
2005
FORD EXPLORER
Reset Check Engine Light
Recently Had Mass Air Flow Replaced And Engine Light Came Back On A Few Days Later, How To I Reset It? Need To Pass Emission Test
Asked by
dwalthers51
1 ANSWER
2001
FORD EXPLORER
What Type Of Power Control Module Do I Need And Where...
I Was Told That I Have To Take The Old One Off First And Get The Number Off Of It. I Was Also Told I Could Get This Info By The Vin. I Also...
Asked by
jamiegreer
1 ANSWER
6 IMAGES
1998
FORD EXPLORER
1993 Ford Explorer How To Clear Codes 411 And 412
We Were Given This 1993 Ford Explorer And Do Not Know Much About It But It Ran Fine Until A Few Months Ago. We Have Replaced The Tps (...
Asked by
meandthree
1993
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Mass Air Flow Sensor Cleaning
How to Replace Serpentine Belt Toyota Prius
Lean Exhaust
Online car repair manuals
