Reverse not working?
TAMASAMOAMONI02
  • 2006 FORD EXPLORER
  • 6 CYL
When I put it in reverse it wont move but when in drive it goes forward. What is the problem and how to I fix it?
Do you
have the same problem?
Monday, July 11th, 2011 AT 5:37 AM
SATURNTECH9
  • 30,870 POSTS
It sounds like you may have a gear range sensor that is out but to be sure lets run down these guides to help us fix it.
and
Monday, July 11th, 2011 AT 6:02 AM
DENBOBBI
  • 6 CYL
  • 107,000 MILES
When I shift from park to reverse, reverse doesn't engage and just revs. Drive and low work fine.
Tuesday, December 22nd, 2020 AT 8:37 AM (Merged)
  • 52,797 POSTS
Good evening,
This sounds like either a clutch issue or a band failure inside the transmission.
I attached a flow chart for you to view. There are many possibilities but most of the time they are internal issues, not external.
MILLHILL
  • 2005 FORD EXPLORER
Transmission problem
2005 Ford Explorer Two Wheel Drive Automatic 58000 miles
sometimes when I put my transmission in reverse it ´s slams into reverse after 2 or 3 seconds, doesn ´t matter warm or cold engine.
In drive it works normal altho sometimes I have the feeling/impression it ´s doing the same only it ´s a gently slam into the next gear
What could be the problem?
  • 107,922 POSTS
Has the trans been serviced? Also, are the u-joints tight and not worn?
MILLHILL
nope, transmission is not serviced yet, something i'm thinking of to do soon now to see if problem dissapears.
Can't tell if U joints are (too) tight, tranny doesn't make a weird noise, it's normal.
Jeff
XLTUSER
  • 2003 FORD EXPLORER
  • 6 CYL
  • 90,000 MILES
Last night while paking the car the reverse gear failed to engage. This reoccurred this morning while taking the car out. Later, down the road, the car appeared to shift between only gears one and two.
  • 107,922 POSTS
Most time when reverse is lost, it has to do with a low reverse band that breaks. Have any check engine lights come on?
XLTUSER
Yes, the "Check Engine" lights are always on. O/D (Overdrive off) lights starts to blink after a while driving. Also, "Check Transmission" flashed on once.
  • 107,922 POSTS
I need you to have the computer scanned for trouble codes. If the lights are on, there will be codes that will direct us to where the problem is coming from.
Most parts stores will scan the OBD 2 for free; however, the trans light requires a different type of scanner and I don't know if they will have it. Start with the engine light and let me know what you find.
DONALD BRINGLE
  • V8
  • 4WD
  • 70,000 MILES
It slips when put in reverse and clunks when starts to move. Only sometimes. Replaced modulator already.
Tuesday, December 22nd, 2020 AT 8:38 AM (Merged)
  • 107,922 POSTS
If the check engine light is on, have the computer scanned. Make sure the trans fluid is full. Check to make sure the low reverse band is adjusted and not broken.
GRIGZRH
  • 5 POSTS
  • 4 CYL
  • 4WD
  • 130 MILES
The red arrow advising if I am in park drive or reverse is not working and the button that fixes my side mirrors is not working. Is this electrical? Can it be fixed. I shipped my car to Trinidad and Tobago where I am l living need to know how before I take it to be fixed.
MERLIN2021
  • 17,250 POSTS
For the mirrors, check the fuse, and if OK, the wires in the rubber conduit that runs from the car into the door usually break inside that conduit. Is the light out on the shifter, or is the problem that the pointer does not move?
GRIGZRH
  • 5 POSTS
No the pointer does not move, and the lights are not off advise
GRIGZRH
  • 5 POSTS
In reference to the reading of PARK/ REVERSE/ DRIVE GEARS. I HAVE TO PUT IT ON AND TRY BEFORE I KNOW WHICH GEAR I AM IN. THANKS
MERLIN2021
  • 17,250 POSTS
1.Remove the lower dash panel. 2.Remove the upper and lower steering column shrouds. 3.Place the range selector lever in the first gear position. 4.Place the range selector lever in the (D) position. This should be two detents from the first gear position. 5.Hand a three-pound weight on the end of the range selector lever. 6.Center the pointer in the middle of the (D) by rotating the thumbwheel on the PRNDL cable housing.7.Remove the three-pound weight from the end of the range selector lever. 8.Install the upper and lower steering column shrouds. 9.Install the lower dash panel.
https://www.2carpros.com/forum/automotive_pictures/62217_1_79.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_2_62.jpg
GRIGZRH
  • 5 POSTS
Is this Issue Electrical?
In the islands the Mechanic shops are different and need to know which one to take it to. The reason for the question above.
Thank you. I am a female and do not know much of these things, but you made me knowledge smart. This is a moment of magic. I cannot wait to tell all my family and friends. You are better than JUST ANSWER.
I can now take it to a Mechanic.
Thanks Mike. Merlin, Bob. Ken and all I missed.
MERLIN2021
  • 17,250 POSTS
The pointer is not electrical, it's a small chord that moves the pointer, something either broke or snapped off. The mirror is electrical, and like I said, is either a broken wire, bad mirror switch, or bad motor in that mirror. Or the fuse!
GRIGZRH
  • 5 POSTS
Thank you. You guys have been great!
