2002 Ford Explorer catalytic coverter
JIMMY2124
  • 2002 FORD EXPLORER
  • 6 CYL
  • 189,000 MILES
Driver side cat is glowing red. Misfire on pass side. Replaced cat still getting hot and glowing at the bottom of cat o2 sensor drops to 0 when givin gas replace plugs and coil and only driver side cat is doing this any ideas. Vehicle runs rough and got a little knocking from pass side
Do you
have the same problem?
Tuesday, September 21st, 2010 AT 8:36 AM
BLUELIGHTNIN6
  • EXPERT
Check timing
Tuesday, September 21st, 2010 AT 11:37 AM
Recommended Guides
