2002 Ford Explorer another blend door
EXPLORER02
  • 2002 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 105,000 MILES
I have an 02 explorer with the same blend door problems as anyone else, I removed the actuator blen door motor because I thought it would fix the problem of no heat, nope, just blows freezing air now, does anyone have a quick fix so I can get heat back, I am trading it in after winter and dont wanna replace everything.
Do you
have the same problem?
Monday, October 4th, 2010 AT 7:07 PM
  • EXPERT
The only thing you can do is tie the door in the position you want it.
Monday, October 4th, 2010 AT 9:50 PM
EXPLORER02
Ty jacoband nicholas, but where is the door located
Tuesday, October 5th, 2010 AT 6:55 AM
  • EXPERT
It is near the heater core.
Tuesday, October 5th, 2010 AT 8:02 AM
EXPLORER02
Thank you for your assistance
Tuesday, October 5th, 2010 AT 10:19 AM
  • EXPERT
Tuesday, October 5th, 2010 AT 10:23 AM
EXPLORER02
Joe do you have any idea where the heater core speciffically is I cant find it
Tuesday, October 5th, 2010 AT 11:54 AM
  • EXPERT
If you look under the hood (firewall), you will see where the heater hoses attach on the firewall. They attach to the heater core. It is on the inside of the vehicle where the hoses attach.
http://www.2carpros.com/forum/automotive_pictures/249084_5_80.jpg
Let me know if you find it.
Tuesday, October 5th, 2010 AT 12:09 PM
EXPLORER02
Joe I think I can see it but what door covers it to flow heat, I dont see anything in front of it
Tuesday, October 5th, 2010 AT 12:20 PM
EXPLORER02
Joe I think I can see it but what door covers it to flow heat, I dont see anything in front of it[/quote:ee8e3f8a62]
ok joe I got into the dash and everything tried moving around the vent doors to try and circulate heat, still no heat anymore ideas you might have
Tuesday, October 5th, 2010 AT 7:06 PM
  • EXPERT
I need you to check something. With the engine at operating temp and the heater on, do both heater core hoses get hot?
Wednesday, October 6th, 2010 AT 7:35 AM
EXPLORER02
Yes joe both are hot.I also checked the coolant flow valve that is also operating correctly. I have no coolant leaking from the heater core or anything
Wednesday, October 6th, 2010 AT 8:26 AM
  • EXPERT
The only thing left is the blend air door. It must not be opening toward the heater core. If the heater core hoses are hot, then the core must be hot. Something is stopping the air from passing over it. That would be the blend air door. That is all that is left.
Try checking it one more time.
Wednesday, October 6th, 2010 AT 9:31 AM
Recommended Guides
