Fuel filter location I need to replace it?
THUNT5002
  • 2003 FORD EXPLORER
Where is the fuel filter located in a 2003 ford explorer?
Sunday, July 25th, 2010 AT 12:53 PM
  • 108,164 POSTS
It's near the tank under the vehicle along fame rail. This video will help you remove the filter with instructions below to show you how to replace the fuel filter in your car.
https://youtu.be/Boi0DPXVHbM
and
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Tuesday, April 2nd, 2019 AT 12:06 PM
JEREMY11
Other Category problem
2003 Ford Explorer V6 Two Wheel Drive Automatic 97000 miles
where is the fuel filter on a 2003 explorer
Wednesday, October 7th, 2020 AT 1:18 PM (Merged)
FLEXY5
  • 512 POSTS
Just forward to the fuel tank on passenger side of frame. Notice a small plastic shroud held on with two small nuts. Remove the shroud to access fuel filter. Easy to change once you find it.
2CP-ARCHIVES
  • 4,542 POSTS
  • 52,797 POSTS
Passenger side of the car, under the front seat under the car covered by a plate.
JEDOLAN
  • 2002 FORD EXPLORER
  • V8
  • 4WD
  • 119,000 MILES
Wednesday, October 7th, 2020 AT 1:19 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Fuel filter is located on the right side frame rail in front of the fuel tank, behind a heat shield and plastic covering.
MAPES191
2002 Ford Explorer V8 Four Wheel Drive Automatic
Where is the fuel filter located?
https://www.2carpros.com/forum/automotive_pictures/12900_fp1_2.gif
Fuel Filter is located at the right rear of vehicle above fuel tank.
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
MAGILICUDY
Engine Mechanical problem
2002 Ford Explorer 6 cyl Two Wheel Drive Automatic
Where is the fuel filter on a ford explorer
CARLIFE65
  • 200 POSTS
Fuel filter is under vehicle, driver side, below seating ara, mounted on the frame in fuel line.
DEBRON
2002 Explorer 4X4, 4.6L V-8, 99,600 miles.
I want to change the fuel filter. Do I need to worry about air in the line since this is a fuel injected engine or will the air take care of itself?
Thanks.
SERVICE WRITER
  • 9,123 POSTS
IT will purge the air itself, don't worry about it. When you go to re-start it, turn the key to the on position and let the pump energize the lines, then turn the key back to off for 5 seconds and return the key to the on position again. Do this a couple times and it will start right up. You can just crank the engine too, it just wears on the starter a little bit but also works.
DEBRON
Thanks Service Writer. I couldn't get a straight answer from the folks at the parts store.
SERVICE WRITER
  • 9,123 POSTS
My pleasure. Some parts guys are very knowledgeable of the operations of parts and some just sell parts.
JO3HN72
  • 6 CYL
  • 4WD
  • 86,000 MILES
Location of fuel filter? I am wanting to change it and cant seem to find it. Help please?
Wednesday, October 7th, 2020 AT 1:20 PM (Merged)
JDL
  • 16,098 POSTS
Welcome to the forum. My info says, under the vehicle, driver side, attached to frame. Looks like quick connect fittings, you may a tool to release fittings, the autostores should sell the tool. Make sure there is no pressure on the system, before taking anything loose. Gas may run out of lines, don't let anything electrical be too close. If too much gas runs out, plug the line, till your ready with new filter. The picture is from autozone.
https://www.2carpros.com/forum/automotive_pictures/170934_explorer_fuel_filter_1.jpg
CASTIDL
  • 6 CYL
  • 12,000 MILES
Where is the fuel filter on this vehicle
OBXAUTOMEDIC
  • 3,711 POSTS
I believe it is located on the inside frame rail on the drivers side around the area of the drivers seat.
Notes
REMOVAL
Relieve the fuel pressure.
Raise the vehicle on a hoist.
Notes
REMOVAL
https://www.2carpros.com/forum/automotive_pictures/12900_filter_1.gif
Remove the fuel filter shield.
1 Remove the nuts.
2 Remove the shield.
https://www.2carpros.com/forum/automotive_pictures/12900_filter2_1.gif
Remove the fuel filter.
1 Disconnect the fuel lines.
2 Remove the fuel filter from the fuel filter support.
INSTALLATION
To install, reverse the removal procedure.
1 Remove the nuts.
INSTALLATION
