2002 Ford Explorer
JACK LIPPETT
  • 2002 FORD EXPLORER
  • V8
  • 4WD
  • 13,000 MILES
Good Afternoon; This truck is running rough sometimes almost stalling with the check engine light flashing. Codes are P0300 ( random misfire) P0306 ( misfire #6) P316 ( not listed but ford says it also means # 6 is misfiring) P1000. After I clear the codes the truck runs fine for a couple of miles then the check engine light starts to flash and with in 5 miles it is running rough. I have replaced all the spark plugs, the capacitor on #6, the Idle air sensor, and the MAFF sensor. In addition I also replaced the fuel filter. I have searched th net for similar problems and the ideas are all over the place. Any ideas would be appreciated. Thanks Jack
Do you
have the same problem?
Tuesday, May 19th, 2009 AT 1:39 PM
DOCFIXIT
  • EXPERT
Hi
Do you have a diagnostic scan tool or code reader? Will need scanner to find out Fords are the hardest of all cars to diagnose. Give a look at the EGR it can cause also fuel pressure, crank sensor and cam pulse wheel all set trhose codes
. The P1000 is set by not clearing completly. After you clear do a quick test to see all codes gone.
Let me know
Thanks for donate
Tuesday, May 19th, 2009 AT 2:14 PM
Recommended Guides
