2001 Ford Explorer theft light on dash blinking
KENNETH D SABOL
  • 2001 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 109,000 MILES
The theft light on the dash is blinking will this prohibit the vehicle from starting? And how can I get it to stop blinking?
Do you
have the same problem?
Sunday, July 25th, 2010 AT 6:18 PM
FIRESTORM
Yes, is is blinking rapidly? Under normal conditions it should flash every 2 seconds. When you turn the key over, but not start it, after 3 seconds the theft light should "prove out".
If it is blinking rapidly you have a problem with the PATS system. You will have to take your vehicle to the dealership to solve this problem. Some locksmiths have the tools to work with it as well.
Sunday, July 25th, 2010 AT 7:03 PM
Recommended Guides
