2000 Ford Explorer transmission slips
JOHN S POWELL
  • 2000 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 110,000 MILES
After driving a couple of miles the OverDrive Off light comes on and will not tuurn off with switch. The transmission appears to begin 'slipping' at that time. I have checked and trans fluid is full.
Any idea's?
Do you
have the same problem?
Saturday, August 29th, 2009 AT 9:48 AM
  • EXPERT
Hi there,
Thank you for the donation,
If you have check the transmission fluid level and it is correct, then you should go get a diagnostic test done on the transmission, there will be a fault code in the ECU, I suggest that you take it to a transmission specialist not a general mechanic as they will have the specialist test equipment to do this diagnostic test for you.
Mark (mhpautos)
Saturday, August 29th, 2009 AT 8:34 PM
Recommended Guides
