2000 Ford Explorer Engine starts then immediatly dies
GANTRYMAN
  • 2000 FORD EXPLORER
Engine Mechanical problem
2000 Ford Explorer 6 cyl Four Wheel Drive Automatic
my explorer will start for a few seconds then it dies. I removed the fuel tank and test the pump and when it is given direct power it works. When I hook it up to the system again it will come on for the first few seconds then I don't hear it come on again even if I release the pressure in the system, unless I turn the key off then on. I gave the pump direct power again and ran the few line to a jerry can and emptied the tank in under a minute and there was lots of pressure. Any ideas of what the problem could be? Any help would be greatly appeciated
Do you
have the same problem?
Sunday, August 22nd, 2010 AT 5:59 PM
  • EXPERT
Have you checked the fuel pump relay?
Sunday, August 22nd, 2010 AT 9:39 PM
Recommended Guides
