1998 Ford Explorer check engine light
LAZYIRANCH
  • 1998 FORD EXPLORER
  • V8
  • 160,000 MILES
I had the codes checked 2 cameup P1309 misfire monitor hardware-CMP misaligned, ckp-cmp noise, pcm aice chip and P0340 camshaft position sensor |A circuit Bank or single sensor. If you could explain in english that would be great thank you John
Do you
have the same problem?
Thursday, October 29th, 2009 AT 12:13 PM
NICK89
Try changing your cam sensor
Thursday, December 3rd, 2009 AT 7:30 PM
Recommended Guides
