1997 Ford Explorer check engine light
JEFFRD390
  • 1997 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 183,000 MILES
My check engine light came on after I spun out im wondering what caused it to come on
Do you
have the same problem?
Tuesday, February 16th, 2010 AT 8:52 PM
OBXAUTOMEDIC
  • EXPERT
Could be almost anything. You could have broke off a sensor, a vacuum line or any number of things. The best thing to do is to go by your local parts store and have them pull codes. Post codes here.
Could also be that some moisture got into a connection or your knocked a connection loose.
Tuesday, February 16th, 2010 AT 8:58 PM
