1997 Ford Explorer
FORDONTHEFARM
  • 1997 FORD EXPLORER
Engine Performance problem
1997 Ford Explorer 6 cyl Four Wheel Drive Automatic
4.0 sohc pressure regulator. Engine runs rough. Disconnected return fuel line from regulator. With engine on, lots of gas flowes from it. Should it be a trickle or nothing at all? The regulator as a steel braded return line crimped on. Cost $600.00 can the cheeper $100.00 one be fitted up.
Do you
have the same problem?
Monday, March 23rd, 2009 AT 10:00 PM
  • EXPERT
It shouldn't leak.
Wednesday, April 8th, 2009 AT 7:47 PM
Recommended Guides
