1996 Ford Explorer AC only works on max air
OUTLAW53
  • 1996 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 144,000 MILES
AC only works on max air, if I move the selector to regular air or vent it blows very hot air. The thermostat does not change the temp.
In the winter the heater only works on max temp. The thermostat does not work for the heater also.
Do you
have the same problem?
Monday, July 26th, 2010 AT 7:32 PM
Check and test the blower motor resistor.
Monday, July 26th, 2010 AT 7:59 PM
Recommended Guides
