1996 Ford Explorer
JAMESLAM
  • 1996 FORD EXPLORER
1996 Ford Explorer 6 cyl Four Wheel Drive Automatic
ford was in a fender bender, and engine stalled when hit. Is ther a reset button for the fuel pump&where is it located?
Do you
have the same problem?
Monday, February 15th, 2010 AT 6:48 PM
BMRFIXIT
  • EXPERT
In event of a collision, electrical contacts in inertia switch open, automatically shutting off fuel pump. Fuel pump shuts off even if engine does not stop running. Engine will starts due to lack of fuel.
Engine cannot be restarted until inertia switch is manually reset. To reset inertia switch, depress button on switch
Inertia Fuel Shutoff located Behind right front kick panel
Monday, February 15th, 2010 AT 7:08 PM
Recommended Guides
